Cannot activate GUI v2 after updating Cerbo GX to 3.50
I eagerly update my Cerbo gx to firmware v3.50 to try the new GUI. But I cannot activate it. I tried everything, Safari on macOS over LAN connection, ipad (Safari over LAN), remote Console from VRM – but the screen is always frozen, I cannot “touch” (or click) the “Next” button in any way.
I see some errors in the browser console, not sure if these are related or not.
Safari browser console:
Firefox browser console:
Any hints of what might be wrong? Thanks in advance,
Josef
Did you try to reboot the GX device (unplugging the power for a few seconds)?
I had the same problem, could not push the next button, frozen screen.
After a reboot the VRM remote console is now fixed. The touch device still shows the old GUI. What went wrong?
Thanks for advice!
Rob Meerwijk
Ok, found the solution. It seems that remote console and touch device are actually not coupled anymore, so not “truely” a remote console. There is a setting under Appearance and language for classic UI and new UI, that you can set on the console. This will change behaviour of the GX touch.
Hi Matthias,
I have a touch screen connected to Cerbo via HDMI and USB, so I tried that and the UI was working as expected from there. So I finished the setup and all works as expected now, both on the touch screen and remotely over LAN or from VRM. Thanks for a quick offer for help.
The new UI looks amazing and works flawlessly. Great job guys, thanks a lot for this!
Josef
I have updated to the new gui2 but it’s not showing in VRM help
