Hey Guys. So I have a VE Bus BMS V1 that I’m trying to upgrade to the V2. The bms connectors on the V2 are different then the V1. Does anyone know how to connect them ?
I’m using 4x330ah victron lithium batteries Daisy chained.
They are the same! I already installed a few of them.
On the picture the female one is just more inside at the V1.
Why should Victron change the connection?
Did you actually tried to connect the BMS cables?
Yes. If looking at the photo I posted the bottom one fits but the top doesn’t. There’s nothing to female thread on the cable to screw into. It’s almost like a push and twist on mine
Can you make a picture of your BMS and the cables?
When I get back on the boat I will
