When I use the Switch Control, I can’t set the initial value of the Dropdown?
Am I missing something?
That’s a beta release.
Ok found the answer.
You need to use Dimming state to set it to the 0 based index of the dropdown values.
The initial value doesn’t seem to work, I can only assume that is cause the virtual switch isn’t available to set the initial state.
I used an inject, but found it has to be no less than 1 sec, anything before that the the state doesnt change, so this aligns with the Initial State of a Switch Control, so would be good if the Initial State would work with the Virtual Switch, not sure how you can get the Virtual Switch to initialise before running the commands to set the value.
Yes mate, its beta, thats fine, I understand. ![]()
