Input from virtual switch and digital input
hi pretty new to node red and have come across a little problem/quirk
im trying to be able to control a relay from two sources 1.digital input 2.virtual switch
it works perfectly from the digital input but when i use the virtual switch on the console or a relay switch it immediately switches back off ive figured this is because its looking at the state of the digital input and switching back off is there any way to prevent this so it can be switched from the two sources independently
heres my flow (excuse the mess its a work in progress)
[ {“id”: “c40847852d74a861”,
“type”: “tab”,
“label”: “Flow 1”,
“disabled”: false,
“info”: “”,
“env”: [ ]
“id”: “5fcfd8712368581d”,
“type”: “victron-input-digitalinput”,
“z”: “c40847852d74a861”,
“service”: “com.victronenergy.digitalinput/1”,
“path”: “/State”,
“serviceObj”: {
“name”: “di20”,
“communityTag”: “digitalinput”
“pathObj”: {
“path”: “/State”,
“type”: “enum”,
“name”: “Digital input state”,
“enum”: {
“0”: “low”,
“1”: “high”,
“2”: “off”,
“3”: “on”,
“4”: “no”,
“5”: “yes”,
“6”: “open”,
“7”: “closed”,
“8”: “ok”,
“9”: “alarm”,
“10”: “running”,
“11”: “stopped”
“name”: “di20”,
“onlyChanges”: false,
“roundValues”: “no”,
“rateLimit”: 0,
“outputs”: 1,
“conditionalMode”: false,
“outputTrue”: “true”,
“outputFalse”: “false”,
“debounce”: “2000”,
“x”: 110,
“y”: 120,
“wires”: \[
“bcf2c740f3fd5d25”
“id”: “16b9b628455f5c83”,
“path”: “/State”,
“serviceObj”: {
“name”: “di20”,
“pathObj”: {
“path”: “/State”,
“type”: “enum”,
“enum”: {
“0”: “low”,
“1”: “high”,
“2”: “off”,
“3”: “on”,
“4”: “no”,
“5”: “yes”,
“6”: “open”,
“7”: “closed”,
“8”: “ok”,
“9”: “alarm”,
“10”: “running”,
“11”: “stopped”
“name”: “di90”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: “2000”,
“x”: 110,
“y”: 40,
“wires”: \[
“b087834a87971ce5”
“id”: “3b38fd0b806bdf45”,
“type”: “switch”,
“name”: “”,
“property”: “payload”,
“propertyType”: “msg”,
“rules”: \[
“t”: “gte”,
“v”: “90”,
“vt”: “num”
“t”: “lt”,
“v”: “80”,
“vt”: “num”
“checkall”: “true”,
“repair”: false,
“outputs”: 2,
“x”: 390,
“y”: 220,
“wires”: \[
“476dbc249dc444c9”
“2fc0320e556a7422”
“id”: “2dcecaa299050c4d”,
“type”: “victron-output-relay”,
“service”: “com.victronenergy.system/0”,
“path”: “/Relay/0/State”,
“serviceObj”: {
“name”: “Venus device”
“pathObj”: {
“type”: “enum”,
“name”: “Venus relay 1 state”,
“enum”: {
“0”: “Open”,
“1”: “Closed”
“mode”: “both”,
“disabled”: false
“name”: “”,
“rateLimit”: 0,
“outputs”: 0,
“condition1Operator”: “>”,
“condition2Enabled”: false,
“condition2Service”: “”,
“condition2Path”: “”,
“condition2Operator”: “>”,
“logicOperator”: “AND”,
“outputOnChange”: false,
“debounce”: 2000,
“x”: 880,
“y”: 220,
“wires”: [ ]
“id”: “2fc0320e556a7422”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “0”,
“tot”: “num”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 620,
“y”: 240,
“wires”: \[
“2dcecaa299050c4d”
“id”: “476dbc249dc444c9”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “1”,
“tot”: “num”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 620,
“y”: 200,
“wires”: \[
“2dcecaa299050c4d”
“id”: “6309b332b76ae1a7”,
“type”: “function”,
“name”: “function 1”,
“func”: “const MAX_LITRES = 54; // <— Change this to your total tank capacity\\n// ---------------------\\n\\nlet high = flow.get(“high_state”) || 2;   // 90% sensor\\nlet mid = flow.get(“mid_state”) || 2;     // 50% sensor (From different Modbus Reg)\\nlet low = flow.get(“low_state”) || 2;     // 20% sensor\\n\\nlet tankLevel = 0;\\n\\n// Logic for Percentage (Checking highest sensor first)\\nif (high === 3) {\\n    tankLevel = 90;\\n} else if (mid === 3) {\\n    tankLevel = 50;\\n} else if (low === 3) {\\n    tankLevel = 20;\\n} else {\\n    tankLevel = 0;\\n}\\n\\n\\n// Calculate Litres\\nlet litres = (tankLevel / 100) \* MAX_LITRES;\\n\\n// Only send if level changed to avoid spamming\\nif (tankLevel !== flow.get(“lastLevel”)) {\\n    flow.set(“lastLevel”, tankLevel);\\n    \\n    // Create the output message\\n    msg.payload = tankLevel; // Main payload is % for Modbus\\n    msg.litres = litres;     // Additional property for Litres\\n    \\n    // Optional: Format a nice string for a Dashboard label\\n    msg.statusText = `${tankLevel}% (${litres}L)`; \\n    \\n    return msg;\\n}\\n\\nreturn null;\\n”,
“outputs”: 1,
“timeout”: 0,
“noerr”: 0,
“initialize”: “”,
“finalize”: “”,
“libs”: [ ],
“x”: 640,
“y”: 80,
“wires”: \[
“e35dd4cb5808d27d”,
“d31d9e85828309e1”
“id”: “1fa5c4cb8067df55”,
“type”: “victron-virtual”,
“name”: “Grey”,
“outputs”: 1,
“device”: “tank”,
“default_values”: true,
“acload_nrofphases”: 1,
“enable_s2support”: false,
“battery_capacity”: 25,
“include_battery_temperature”: false,
“battery_voltage_preset”: “24”,
“battery_voltage_custom”: 24,
“generator_type”: “ac”,
“generator_nrofphases”: 1,
“include_engine_hours”: false,
“include_starter_voltage”: false,
“include_history_energy”: false,
“grid_nrofphases”: 1,
“include_motor_temp”: false,
“include_controller_temp”: false,
“include_coolant_temp”: false,
“include_motor_rpm”: true,
“include_motor_direction”: true,
“position”: 0,
“pvinverter_nrofphases”: 1,
“switch_1_type”: 1,
“switch_1_min”: 0,
“switch_1_max”: “”,
“switch_1_initial”: 0,
“switch_1_label”: “”,
“switch_1_unit”: “”,
“switch_1_step”: 1,
“switch_1_customname”: “”,
“switch_1_group”: “”,
“switch_1_include_measurement”: false,
“switch_1_rgb_color_wheel”: false,
“switch_1_cct_wheel”: false,
“switch_1_rgb_white_dimmer”: false,
“fluid_type”: “2”,
“include_tank_battery”: false,
“include_tank_temperature”: false,
“tank_battery_voltage”: 3.3,
“tank_capacity”: “0.054”,
“temperature_type”: 2,
“include_humidity”: false,
“include_pressure”: false,
“include_temp_battery”: false,
“temp_battery_voltage”: 3.3,
“x”: 790,
“y”: 120,
“wires”: \[
“id”: “e35dd4cb5808d27d”,
“type”: “victron-output-custom”,
“service”: “com.victronenergy.tank/100”,
“path”: “/Level”,
“serviceObj”: {
“name”: “Grey (100)”
“pathObj”: {
“path”: “/Level”,
“name”: “/Level”,
“type”: “number”,
“value”: 90
“name”: “”,
“rateLimit”: 0,
“outputs”: 0,
“debounce”: 2000,
“x”: 830,
“y”: 40,
“wires”: [ ]
“id”: “b087834a87971ce5”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “topic”,
“pt”: “msg”,
“to”: “sensor_high”,
“tot”: “msg”,
“dc”: true
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 300,
“y”: 40,
“wires”: \[
“52c10766e083df7b”
“id”: “bcf2c740f3fd5d25”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “topic”,
“pt”: “msg”,
“to”: “sensor_low”,
“tot”: “str”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 300,
“y”: 120,
“wires”: \[
“cb5630b0ad48a651”
“id”: “52c10766e083df7b”,
“type”: “function”,
“name”: “function 2”,
“func”: “flow.set(“high_state”, msg.payload);\\nreturn msg; // Optional: wire this to the Logic node\\n”,
“outputs”: 1,
“timeout”: 0,
“noerr”: 0,
“initialize”: “”,
“finalize”: “”,
“libs”: [ ],
“x”: 480,
“y”: 40,
“wires”: \[
“6309b332b76ae1a7”
“id”: “cb5630b0ad48a651”,
“type”: “function”,
“name”: “function 3”,
“func”: “flow.set(“low_state”, msg.payload);\\nreturn msg; // Optional: wire this to the Logic node\\n”,
“outputs”: 1,
“timeout”: 0,
“noerr”: 0,
“initialize”: “”,
“finalize”: “”,
“libs”: [ ],
“x”: 480,
“y”: 120,
“wires”: \[
“6309b332b76ae1a7”
“id”: “74795c6b8e379674”,
“type”: “victron-input-tank”,
“service”: “com.victronenergy.tank/23”,
“path”: “/Level”,
“serviceObj”: {
“name”: “BLACK”,
“communityTag”: “tank”
“pathObj”: {
“path”: “/Level”,
“type”: “float”,
“name”: “Tank level (%)”
“name”: “”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: “2000”,
“x”: 160,
“y”: 220,
“wires”: \[
“3b38fd0b806bdf45”
“id”: “fe1c25a5aafef6d6”,
“type”: “function”,
“name”: “function 4”,
“func”: “flow.set(“mid_state”, msg.payload);\\nreturn msg; // Optional: wire this to the Logic node\\n”,
“outputs”: 1,
“timeout”: 0,
“noerr”: 0,
“initialize”: “”,
“finalize”: “”,
“libs”: [ ],
“x”: 480,
“y”: 80,
“wires”: \[
“6309b332b76ae1a7”
“id”: “fb1ec6bd96016891”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “topic”,
“pt”: “msg”,
“to”: “sensor_mid”,
“tot”: “str”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 300,
“y”: 80,
“wires”: \[
“fe1c25a5aafef6d6”
“id”: “efa8a1fbee8f7d1f”,
“path”: “/State”,
“serviceObj”: {
“name”: “di20”,
“pathObj”: {
“path”: “/State”,
“type”: “enum”,
“enum”: {
“0”: “low”,
“1”: “high”,
“2”: “off”,
“3”: “on”,
“4”: “no”,
“5”: “yes”,
“6”: “open”,
“7”: “closed”,
“8”: “ok”,
“9”: “alarm”,
“10”: “running”,
“11”: “stopped”
“name”: “di50”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: “2000”,
“x”: 110,
“y”: 80,
“wires”: \[
“fb1ec6bd96016891”
“id”: “d0f33c71599be95b”,
“type”: “victron-input-temperature”,
“service”: “com.victronenergy.temperature/23”,
“path”: “/Temperature”,
“serviceObj”: {
“name”: "Cooker ",
“communityTag”: “temperature”
“pathObj”: {
“type”: “float”,
“name”: “Temperature (°C)”
“name”: “”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: “2000”,
“x”: 170,
“y”: 320,
“wires”: \[
“eed8978b4d237b37”,
“42f670f689b472c8”
“id”: “eed8978b4d237b37”,
“type”: “switch”,
“name”: "Cooker fan ",
“rules”: \[
“t”: “gte”,
“v”: “40”,
“vt”: “str”
“t”: “lte”,
“v”: “30”,
“vt”: “str”
“checkall”: “true”,
“repair”: false,
“outputs”: 2,
“x”: 410,
“y”: 300,
“wires”: \[
“92d79ee2136074a6”
“92d79ee2136074a6”
“id”: “42f670f689b472c8”,
“type”: “switch”,
“name”: "Cooker gas shut off ",
“rules”: \[
“t”: “gte”,
“v”: “120”,
“vt”: “str”
“t”: “lte”,
“v”: “110”,
“vt”: “str”
“checkall”: “true”,
“repair”: false,
“outputs”: 2,
“x”: 430,
“y”: 360,
“wires”: \[
“86e8f8bf966f2c20”,
“b69fe25b2b7c2419”
“86e8f8bf966f2c20”
“id”: “92d79ee2136074a6”,
“service”: “”,
“path”: “”,
“name”: “”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: 2000,
“x”: 680,
“y”: 300,
“wires”: \[
“id”: “86e8f8bf966f2c20”,
“service”: “”,
“path”: “”,
“name”: “”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: 2000,
“x”: 680,
“y”: 360,
“wires”: \[
“id”: “f713592f6d79b0a6”,
“type”: “switch”,
“name”: “”,
“rules”: \[
“t”: “gte”,
“v”: “90”,
“vt”: “num”
“t”: “lt”,
“v”: “80”,
“vt”: “num”
“checkall”: “true”,
“repair”: false,
“outputs”: 2,
“x”: 390,
“y”: 220,
“wires”: \[
“id”: “915e95cdac92eb1c”,
“type”: “switch”,
“name”: “”,
“rules”: \[
“t”: “lte”,
“v”: “89”,
“vt”: “str”
“t”: “gte”,
“v”: “92”,
“vt”: “str”
“checkall”: “true”,
“repair”: false,
“outputs”: 2,
“x”: 390,
“y”: 560,
“wires”: \[
“cf3fb907c6f1ec3e”
“0ffd89653351baf3”
“id”: “cf3fb907c6f1ec3e”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “0”,
“tot”: “num”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 580,
“y”: 540,
“wires”: \[
“d0667a599443181c”
“id”: “0ffd89653351baf3”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “1”,
“tot”: “num”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 580,
“y”: 580,
“wires”: \[
“d0667a599443181c”
“id”: “d0667a599443181c”,
“serviceObj”: {
“pathObj”: {
“type”: “enum”,
“enum”: {
“0”: “Open”,
“1”: “Closed”
“mode”: “both”,
“disabled”: false
“name”: “”,
“rateLimit”: 0,
“outputs”: 0,
“debounce”: 2000,
“x”: 840,
“y”: 560,
“wires”: [ ]
“id”: “10d59debec43d2a6”,
“service”: “com.victronenergy.digitalinput/3”,
“path”: “/State”,
“serviceObj”: {
“name”: “LPG Input”,
“pathObj”: {
“path”: “/State”,
“type”: “enum”,
“enum”: {
“0”: “low”,
“1”: “high”,
“2”: “off”,
“3”: “on”,
“4”: “no”,
“5”: “yes”,
“6”: “open”,
“7”: “closed”,
“8”: “ok”,
“9”: “alarm”,
“10”: “running”,
“11”: “stopped”
“name”: “”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: “2000”,
“x”: 180,
“y”: 740,
“wires”: \[
“77201feb1810bcf4”
“id”: “e709836b88a6f6c9”,
“serviceObj”: {
“pathObj”: {
“type”: “enum”,
“enum”: {
“0”: “Open”,
“1”: “Closed”
“mode”: “both”,
“disabled”: false
“name”: “”,
“rateLimit”: 0,
“outputs”: 0,
“debounce”: 2000,
“x”: 840,
“y”: 720,
“wires”: [ ]
“id”: “6adf4c1cc6789c54”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “0”,
“tot”: “num”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 580,
“y”: 700,
“wires”: \[
“e709836b88a6f6c9”
“id”: “927bb6140c59b75b”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “1”,
“tot”: “num”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 580,
“y”: 740,
“wires”: \[
“e709836b88a6f6c9”
“id”: “77201feb1810bcf4”,
“type”: “switch”,
“name”: “”,
“rules”: \[
“t”: “eq”,
“v”: “2”,
“vt”: “num”
“t”: “eq”,
“v”: “3”,
“vt”: “num”
“checkall”: “true”,
“repair”: false,
“outputs”: 2,
“x”: 390,
“y”: 740,
“wires”: \[
“6adf4c1cc6789c54”
“927bb6140c59b75b”
“id”: “af3171e468de956f”,
“type”: “switch”,
“name”: “”,
“rules”: \[
“t”: “eq”,
“v”: “2”,
“vt”: “num”
“t”: “eq”,
“v”: “3”,
“vt”: “num”
“checkall”: “true”,
“repair”: false,
“outputs”: 2,
“x”: 390,
“y”: 900,
“wires”: \[
“321c6b36d0b15d4c”
“d2472e3adac04f6f”
“id”: “c0e13efd25386d26”,
“type”: “switch”,
“name”: “”,
“rules”: \[
“t”: “eq”,
“v”: “2”,
“vt”: “num”
“t”: “eq”,
“v”: “3”,
“vt”: “num”
“checkall”: “true”,
“repair”: false,
“outputs”: 2,
“x”: 390,
“y”: 1040,
“wires”: \[
“37df86fda9091897”
“a81740063ee96a1c”
“id”: “321c6b36d0b15d4c”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “0”,
“tot”: “num”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 580,
“y”: 860,
“wires”: \[
“8c0951b6ab20e8ba”
“id”: “d2472e3adac04f6f”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “1”,
“tot”: “num”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 580,
“y”: 900,
“wires”: \[
“8c0951b6ab20e8ba”
“id”: “37df86fda9091897”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “”,
“tot”: “str”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 580,
“y”: 1000,
“wires”: \[
“e1c3c6b3ee80679e”
“id”: “a81740063ee96a1c”,
“type”: “change”,
“name”: “”,
“rules”: \[
“t”: “set”,
“p”: “payload”,
“pt”: “msg”,
“to”: “”,
“tot”: “str”
“action”: “”,
“property”: “”,
“from”: “”,
“to”: “”,
“reg”: false,
“x”: 580,
“y”: 1040,
“wires”: \[
“e1c3c6b3ee80679e”
“id”: “bb46bea3ba854682”,
“service”: “com.victronenergy.digitalinput/4”,
“path”: “/State”,
“serviceObj”: {
“name”: “Inverter input”,
“pathObj”: {
“path”: “/State”,
“type”: “enum”,
“enum”: {
“0”: “low”,
“1”: “high”,
“2”: “off”,
“3”: “on”,
“4”: “no”,
“5”: “yes”,
“6”: “open”,
“7”: “closed”,
“8”: “ok”,
“9”: “alarm”,
“10”: “running”,
“11”: “stopped”
“name”: “”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: “2000”,
“x”: 190,
“y”: 900,
“wires”: \[
“af3171e468de956f”
“id”: “04167d4c241d031e”,
“service”: “”,
“path”: “”,
“name”: “”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: 2000,
“x”: 130,
“y”: 1040,
“wires”: \[
“c0e13efd25386d26”
“id”: “8c0951b6ab20e8ba”,
“path”: “/Relay/1/State”,
“serviceObj”: {
“pathObj”: {
“type”: “enum”,
“name”: “Venus relay 2 state”,
“enum”: {
“0”: “Open”,
“1”: “Closed”
“mode”: “both”
“name”: “”,
“rateLimit”: 0,
“outputs”: 0,
“debounce”: 2000,
“x”: 840,
“y”: 880,
“wires”: [ ]
“id”: “e1c3c6b3ee80679e”,
“service”: “”,
“path”: “”,
“name”: “”,
“rateLimit”: 0,
“outputs”: 1,
“debounce”: 2000,
“x”: 780,
“y”: 1020,
“wires”: \[
“id”: “b69fe25b2b7c2419”,
“type”: “victron-inject”,
“name”: “”,
“notificationType”: “1”,
“notificationTitle”: “Cooker Temperature High”,
“x”: 690,
“y”: 420,
“wires”: \[
“id”: “d31d9e85828309e1”,
“type”: “victron-modbus”,
“name”: “”,
“unitid”: “com.victronenergy.tank | Unit ID :100”,
“attribute”: {
“label”: “com.victronenergy.tank:/Level”,
“value”: “3004:uint16:1:10:%:R”
“attributesPath”: “”,
“write”: true,
“server”: “127.0.0.1”,
“x”: 940,
“y”: 80,
“wires”: \[
“id”: “aada117b71a68832”,
“type”: “victron-virtual-switch”,
“name”: “Cooker fan”,
“outputs”: 2,
“switch_1_type”: 1,
“switch_1_customname”: “Cooker Fan”,
“switch_1_group”: “R2VER”,
“x”: 370,
“y”: 1120,
“wires”: \[
“id”: “53e98b8a5d4cbc89”,
“name”: “LPG Valve”,
“outputs”: 2,
“switch_1_type”: “1”,
“switch_1_customname”: “LPG Valve”,
“x”: 370,
“y”: 680,
“wires”: \[
“id”: “3e031a248db7bbf4”,
“name”: “Inverter”,
“outputs”: 2,
“switch_1_type”: 1,
“switch_1_customname”: “Inverter”,
“x”: 380,
“y”: 840,
“wires”: \[
“id”: “fa0ba894312b6134”,
“name”: “Water Valve”,
“outputs”: 2,
“switch_1_type”: 1,
“switch_1_customname”: “Water Valve”,
“x”: 370,
“y”: 1000,
“wires”: \[
“id”: “ac035efea557ae46”,
“type”: “global-config”,
“env”: [ ],
“modules”: {
“@victronenergy/node-red-contrib-victron”: “1.6.63”,
“node-red-contrib-victron-modbus”: “1.0.0”
well i cant get the flow to post properly !!!
You can’t have 2 sources of input controlling one output unless one input has priority over the other. It’s why Victron has included a 3 way switch option.
The other way is to use a function node reading the state of both inputs and defining your own logic in there using IF statements to give priority to one or the other, or making it 1 out of 2 voting, i.e. Both off = off, any 1 on = on, both on = on.
Figured it out with help of google ai
Il post the code up later
Hi there, any chance you could show code used please?
