Virtual switch with dynamic dropdown options
Has anyone managed to dynamically set options for the dropdown type of virtual switch? If so, how did you manage to set your options?
The test flow below shows a simplified form what I am trying to do. I have tried following both the example javascript in the help attached to the virtual switch node and the longer configuration definition set out in the Venus OS dbus switch specification. In both cases the error text is “Invalid value types for keys: /SwitchableOutput/output_1/Settings/Labels. Expected: string, number, boolean, null, or array of numbers.
I am using firmware version 3.71 on my Cerbo-S GX.
        "id": "ef5b123c0a22b959",
        "type": "tab",
        "label": "Test",
        "disabled": false,
        "info": "",
        "env": []
        "id": "4d6815f75342ba53",
        "type": "victron-virtual-switch",
        "z": "ef5b123c0a22b959",
        "name": "",
        "outputs": 3,
        "switch_1_type": "8",
        "switch_1_min": "1",
        "switch_1_max": "3",
        "switch_1_initial": 0,
        "switch_1_label": "",
        "switch_1_unit": "",
        "switch_1_step": 1,
        "switch_1_customname": "No. of options",
        "switch_1_group": "Test",
        "switch_1_include_measurement": false,
        "switch_1_rgb_color_wheel": false,
        "switch_1_cct_wheel": false,
        "switch_1_rgb_white_dimmer": false,
        "x": 200,
        "y": 140,
        "wires": [
                "ec56d82501e08c11",
                "e124bed4414c85e3"
        "id": "ec56d82501e08c11",
        "type": "switch",
        "name": "",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "lt",
                "v": "2",
                "vt": "num"
                "t": "eq",
                "v": "2",
                "vt": "num"
                "t": "gt",
                "v": "2",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 3,
        "x": 410,
        "y": 140,
        "wires": [
                "bff701b4f45982db"
                "da5f3ce5feeb3ba6"
                "24a4a2b4396e0dfa"
        "id": "bff701b4f45982db",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "{\"/SwitchableOutput/output_1/Settings/DimmingMin\":0,\"/SwitchableOutput/output_1/Settings/DimmingMax\":1,\"/SwitchableOutput/output_1/Settings/Labels\":[\"0\"]}",
                "tot": "json"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 620,
        "y": 100,
        "wires": [
                "f9fea3716cef7032"
        "id": "da5f3ce5feeb3ba6",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "{\"/SwitchableOutput/output_1/Settings/Labels\":[\"First\",\"Second\"]}",
                "tot": "json"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 620,
        "y": 140,
        "wires": [
                "f9fea3716cef7032"
        "id": "24a4a2b4396e0dfa",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "{\"/SwitchableOutput/output_1/Settings/Labels\":[\"First\",\"Second\",\"Third\"]}",
                "tot": "json"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 620,
        "y": 180,
        "wires": [
                "f9fea3716cef7032"
        "id": "f9fea3716cef7032",
        "name": "",
        "outputs": 2,
        "switch_1_type": "6",
        "switch_1_min": 0,
        "switch_1_max": "",
        "switch_1_step": 1,
        "switch_1_customname": "Test dropdown",
        "x": 880,
        "y": 140,
        "wires": [
        "id": "e124bed4414c85e3",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 400,
        "y": 260,
        "wires": []
        "id": "589635a1b75c709e",
        "type": "global-config",
        "env": [],
        "modules": {
            "@victronenergy/node-red-contrib-victron": "1.6.63"
Appears to be a bug. Can confirm the same, have logged an issue on git.
Thanks for the report.
Thanks Nick.
Looks like this has been fixed and should be in one of the next betas.
Excellent
Fix is in 3.72~3 beta
Beta now installed and can confirm my flow working as expected.
Victron at its best! Thanks to all.
