Victron Virtual Switch (Number Input) write not working
I’m trying out the new Virtual Switch node set up as a Number Input. It works fine the other way around: if I change the value in the Victron GUI, it immediately spits the new value out on output 3 like it should.
Where I’m stuck is setting a value from Node-RED. My test input function for the node looks like this:
msg.payload = {
“/SwitchableOutput/output_1/Value”: 4
return msg;
When I trigger it the node status says “Updated 1 path (101)” , the payload passes straight through to output 1, and the debug window throws:
Failed to apply debounced value for /SwitchableOutput/output_1/Value: Property SwitchableOutput/output_1/Value not found in properties.
Nothing changes in the GUI the value remains unchanged.
Reading the value from the GUI works perfectly, it updates Node-RED straight away. But writing back just doesn’t seem to do anything.
Am I doing something wrong here, or is writing to Number Input virtual switches from Node-RED not actually supported yet?
Any pointers would be much appreciated.
Meini
I think the path for the numeric input is “/SwitchableOutput/output_1/Dimming”, not Value.
Thank you Nicolas! I really appreciate your fast response.
I would have never guessed. How do you know this? Trial and error? I can’t find any documentation going into those things other than the ones inside Node-RED and that’s not explaining much about the input values.
I had the same problem with the slider, where the path in the Node-RED documentation is wrong.
I find the easiest way to check is to connect via ssh on the VenusOs device and use dbus-spy to look what path are available on dbus for the node I’m trying to use.
Did you try the help tab in nodered? Seems pretty self-explanatory:
Yes, the thing is the inline documentation of the “Basic slider” is wrong (still is in 3.80~7) : Value instead of Dimming
In 3.72~1 the “Numeric input” documentation still talk about Value, but it’s corrected in 3.80~7.
This can be confusing and maybe others are wrong too, so I check before creating my flux.
There have been a few fixes in 3.80 which don’t appear to be backported to 3.7x.
