Using cerbo gx with Xantrex inverter via nema2000
Hi All - my 5th wheel
Came with a Xantrex 2000 inverter which has the data port for nema2000. Additionally I have a victron shaft shunt and solar charger.
I wanted to pull that all together with a Cerbo gx. I see there is a nema2000 to ve.can cable that victron sells.
From initial research it looks like this cable is more for connecting victron things to the nema network. So here is the question. If I connect the inverter via nema cable to ve.can on cerbo gx will I be able to see usage, draw, turn off inverter?
Thanks I’m a complete nube to this.
Read the manual, Section 5, connecting non Victron products and the only items it lists as connectable by NMEA2000 are GPS, Tank level senders and alternators, products Victron does not supply. The GX is not a generic NMEA2000 display.
Thank you - I appreciate you help
