I need to turn on the BMV 712 relay to control a external relay.
At 96% SOC turn on the BMV 712 relay to power on the external relay
Hold BMV 712 relay on till 86 % SOC then turn the relay off.
Repeat again when SOC gets back to 96%
Do I use on the low SOC relay a clear value of 96% to turn on the relay and a set value of 86% to turn off the relay
Do I use the common — N/O or the common—–N/C for the control to my external relay
Do I use the invert mode with any of the above connections
Thank You
