As the energy prices go well below zero on solar peak hours today, I am turning off my SolarEdge inverter on those hours today.
Would it be possible to turn off the mppt-trackers on my MultiRS in a similar way through software (preferably NodeRed) so that the system can still draw power from the grid instead? I know the system is very capable of throttling down solar input, yet I am unable to find the way to control this manually.
Would it not be easier to use ESS’s export limit option to 0watts
Which can be set in node red.
I’m not familiar with solaredge but if you’ve setup frequency shifting (assuming it’s supported) I think that ESS functionality should manage it all for you?
For clarity, I am succesfully turning off my SolarEdge inverter through RRCR Power Control. Simply put I connected two wires to the relay on one of my MultiRS’s and closing that relay tells the SolarEdge to stop producing energy.
What I am unable to achieve is shutting down my panels connected directly to the internal MPPT connections of my MultiRS. Obviously the manual breaker switch under the MultiRS accomplishes this, but I need to be present to do that, and I doubt how much that breaker likes to be switched off under load on a daily basis.
I agree. That is not what it is there for. I have separate brekers on the strings. If i get a few minues will dig deeper to see if there a sfotware option that doesn’t affect charging from grid as well
In this moment there is no documented way on how to disable tracker 1 or 2 (or 3 or 4 on MPPT450/200)…
It would be a nice feature next to the name of the tracker…
Something like this:
I am also looking for this. Negative prices are now quite common, and I would like to charge from the net during those hours instead of from the solar panels. Even a simple setting exposed through MQTT would already be helpful.
As I described above you need to create a custom control node to directly modify the /Pv/Disable dbus path for the MultiRS. (0 for enable, 1 for disable, setting is synced to all my 3 multiRS units working together in my 3phase group)
I’ve been using it to turn off my solar panels on the 5-10 days each year that prices are so far below zero that it actually benefits me to not have solar active for a few hours.
You obviously should be fully aware of the risks and consequences of using custom control nodes: A custom output node can use the found services and paths on the dbus for writing to. This is particularly handy when you need to write to a service/path that is not available (yet) in an existing node.
Downside of using the custom node is that there is no guarantee that the service and path will remain existent with firmware updates. It also requires more knowledge of the underlying system as the services and paths for the custom nodes don’t come with documentation. There are services and paths that are not supposed to be written to by third party services.
Since this is fully undocumented I have no information about limitations or restrictions.
