I am located in Adelaide, South Australia and have a Multi RS Solar hybrid inverter plus a 15kWh LifePo battery bank with a JK Inverter BMS. 1.5 kW of PV panels are currently connected to the Multi RS. I’m using a Raspberry Pi 4B running Venus OS ver. 3.63 to communicate with the Multi RS and BMS.
My objective is charge the battery from the grid when the tariff is at its lowest.
The battery is mainly charged by PV power and I currently top it up by manually switching on the grid during the shoulder tariff period.
My energy retailer’s shoulder time is daily between 10:00 and 15:00.
The problem is that I’m not able to program the Multi RS to charge from the grid at set times.
I’ve read several misleading articles that state the Multi RS supports “Scheduled Charging”. The Multi RS manual states that the unit only has limited ESS functionality and “Scheduled Charging” is not available on its menu. Other Victron articles explain that Scheduled Charging will only work on some Victron devices e.g. the MultiPlus via the VE.Bus port which the Multi RS does not have.
From what I’ve researched, Node Red is not supported on the Multi RS because it needs to communicate via the VE.Bus.
The Multi RS does have two Aux Inputs (“analog/digital”- 5V logic) that can start and stop grid charging by switching the AC Input relay.
Has anyone configured a Raspberry Pi to control charging times via the Aux Inputs?
Hi @rrusek,
I have the same system: Multi RS Solar 48/6000 + DIY 280Ah + inverter JK BMS, and can set a schedule in ESS.
Try to update your system to the latest stable version of VenusOS 3.64 and MultiRS to version 1.25.
Alternatively, you can use DESS, which charges your battery at the lowest price, but it will take approximately 28 days to learn the system.
My Multi RS was at V 1.25 and I have updated Venus OS to V 3.64.
However, the only ESS menu I can enter is via Victron Connect. I still cannot find any setting for scheduling in ESS in it. A screenshot of it is attached.
It will take me a while to fully setup DESS.
Is the attachment you included from DESS?
It’s not VictronConnect app, it’s the remote console Venus OS UI (GUIv2).
You can access it from the same network as Cerbo GX by URL: https://venus.local/gui-v2/
or from VRM:
login to VRM → select installation → Settings → General
Thank you for pointing out that you are using the New UI for the VRM Remote Console. I am new to Victron and had only used the Classic UI so did not recognise its format but have now switched to it.
However, I still can’t get the Sheduled charge levels menu to appear. When I enter ESS, there is a message saying that “ESS settings are available on the RS System product page”.
I have set the Multi RS to be Optimized without battery life under the ESS mode.
As you can access ESS on your system and the menu does show scheduled charge levels when I use the “demo mode” on mine, I probably have an incorrect setting somewhere that I need to sort out.
I have noticed that the Overview and Multi RS Solar tabs are not present on my menu.
One question still stands…
Those settings, because of the Venus OS’s breadcrumbs, are the settings of the Multi RS.
In this moment is or is not possible, for Multi RS, to set the same ESS things through VictronConnect ?
It seems not, even if the OP has 1.25 in Multi RS and 3.64 in Venus OS…
Thank you all for the advice regarding my Multi RS scheduled charging issue.
I followed the breadcrumb trail as suggested and was able to setup ESS under the Devices tab rather than System Setup.
Charging now turns on and off at the set times.
I haven’t thoroughly tested the system yet but while the battery was being charged today I did notice that the PV power was substantially reduced as soon as the grid connected. When I manually connected to the grid using the “Keep batteries charged” setting, it would supplement the available PV power. Hopefully this ESS configuration just requires some tweaking so that PV power will be utilized as much as possible.
I’m wanting to connect a raspberry pi running Venus os to my multi rs solar but I’m not exactly sure how to go about it. If possible could you please point me in the right direction to do so?
Connecting your Victron Multi RS to a Raspberry Pi is a great idea and it works well.
If you just need to be pointed in the right direction, I would suggest looking at Andy’s Off Grid Garage videos as a starter. His video on how to get started with a RPi provides step by step instructions on how to load Venus OS onto it and is entertaining at the same time.
The link to Andy’s video is:
Look into Andy’s other videos on how to use the CAN bus.
I did not find much specific information on connecting a Raspberry Pi to the Multi RS. Most of the online information relates to the MultiPlus or Quattro units. Unlike those units the Multi RS communicates via VE.CAN. So you need to do a bit of research but if you are an enthusiastic DIYer you will be rewarded in the end with a capable system.
My PV system centres on a Multi RS. It has two 2.4 kW PV banks of panels. The battery bank consists of two Yixiang 16 KW/h battery boxes which have JK 200A inverter BMSs. The components communicate via a RPi 4b running Venus OS. The RPi has a dual CAN hat. The Multi RS communicates with the RPi via CAN 0. One BMS communicates with the RPi on CAN 1 and the other via a RS485/USB converter.
You can connect the Multi RS to a RPi using a VE.Direct cable but it only provides limited communication. If you need to charge the battery bank using ESS you will have to use the VE.CAN port.
Thank you for taking the time to give me all that information I genuinely appreciate it.
My setup is completely off grid. I have the Multi rs solar with two strings of solar almost 3kw each. This is connected to a 48v 280ah EEL battery which has the JK BMS. I have installed/built everything myself with a lot of help from YouTube, especially Andy’s off grid garage.
I have recently purchased a raspberry pi 3B to run the Venus OS mainly for the purpose of having a VRM so I can monitor the solar when I’m not at home. Connecting the battery to the Multi would be a nice feature but not as important.
At the moment I’m trying to work out whether to use a CAN hat or some kind of USB to CAN adaptor which will plug into the VE.can port. I’m unsure as to what type of cable I will need and what rewiring will be required.
You are welcome. I am pleased to pass on what I have learnt along the way.
Until a few weeks ago my system was communicating with the Multi RS via a PCAN isolated CAN/USB interface. It was very reliable but I wanted to also check the BMSs remotely so I switched to a Waveshare dual isolated CAN hat. I think the CAN hat is more compact and tidier than the USB option. It was lower in cost than the PCAN isolated CAN/USB interface I bought.
For the VE.CAN port I just used a standard patch lead and cut off one of the RG45 connectors.
Brown = CAN low
White/green = Ground
White/brown = CAN high
Have a look at Kevin Windrem’s site for installing the Venus OS / VE.CAN package. The link is:
You will find that Andy has a couple of good videos on setting up CAN communications.
One other thing I’m unsure of, I have read about needing termination RJ45 plugs for the remaining VE.can port to help maintain a stable connection. Is this something you have done?
Thanks for the suggestion I’ll see how the cheaper one goes and if I have any issues I might upgrade at a later date.
I was reading in another post you mentioned you don’t use any ve.can termination plugs with your cerbo to pylontech battery. What type of inverter or charge controller are you using and do you use termination plugs in that?
On battery connection I have a Cerbo connected with a Pylontech pack. The distance is 1.5m.
Pylontechs have a terminator on their side enabled by switches.
On Cerbo I don’t have the terminator as the distance between batteries and Cerbo is small and there is no need for the second terminator, as the reflected wave is not posing any problems for that CAN speed.
For that distance, the signal reflection completes its chaotic bouncing and completely settles down long before the CAN controllers sample the voltage to read the bits.
The same on Cerbo to Multi RS Solar. Only one terminator on Multi RS.
The distance is about 20cm as the Cerbo is magnetically fixed on the Multi RS housing.
When I bought my Multi RS it was supplied with a CAN terminator for the second VE.Can port.
A photo of the configuration that works for me is attached.
If you don’t have the terminator, it just looks like a 1/4 W 120 Ohm resistor crimped into a RG45.
