DESS throttling mppt solar while charging from grid
Hi all,
I am running a 3-phase MultiRS setup managed by VRM DESS.
The system has planned the feed back solar energy to the grid in the morning while prices are still reasonably high, charge the battery from grid and solar at the three hours with the lowest prices, feed excess solar back to the grid when prices rise again in the afternoon and empty the battery in the evening at the best prices… So far all seems well.
However while charging the battery at the three lowest price hours, I notice that my MultiRS throttles the MPPT down to be able to draw more power from the grid. Prices are low but still well above zero.
Manually limiting grid current (if needed all the way to zero) allows the solar panels to go up to full power again.
I would prefer my solar panels to only be throttled at tarifs below zero, or to prevent overcurrent situations. Am I missing a setting somewhere? Is there an easy way to manipulate this from Node-Red without having to fully create a DESS in NodeRed?
I am very pleased with the MultiRS performance but figuring out how to fully tweak ESS/DESS from NodeRed is somewhat of a challenge.
we recently discovered this behaviour and a fix is being worked on.
It requires some changes, so we cannot say when this will be released.
For the time you could only limit the battery charge rate in DESS to a value that would allow your multirs to utilize 100% dcpv and only pull the difference from grid. Or if dcpv is enough to saturate the mpptrs output, place a grid2battery restriction during the questionable hours and DESS will schedule accordingly to not request additional power from grid.
Something like:
Thanks for your swift and clear response.
Given that I can detect the unwanted behaviour from the "MultiRS | MPP operation mode " in NodeRed I chose to create a rudimentary feedback loop gradually lowering my AC Current Limit while the MPPtracker shows ‘1 - voltage/current limited’ and gradually raising my AC Current Limit if it is operating at full capacity…
Obviously this limits all three of my MultiRS’s because the AC Current Limit is a global setting, but that is a small price to pay compared to wasting solar from my roof while buying energy from the grid :slight_smile:
On a sidenote:
Given that the MultiRS can obviously throttle the onboard MPPT an easy way to actively control this throttling from NodeRed for optimising revenue by charging the battery from the grid instead of the MPPT in case of well below zero energy prices is on my wishlist for the future…
A simple on/off switch for the onboard mppt while still allowing charging from the grid could work about as well for me, I guess…
Thanks for confirming, any indication on a due date? My ESS system is also suffering from it. And the workarounds are quite cumbersome.
I’ve been testing extensively to optimally use my solar panels without blocking my ability to charge my batteries from the grid as well at the cheaper hours if the sun does not suffice…
It seems to work slightly better if I temporarily change from ‘optimized without battery life’ to ‘keep batteries charged’ and I am now only reducing allowable grid current if I notice that the mppt tracker is ‘voltage/current limited’ AND the mppt voltage goes up too much (in my case above 195V for my 6 panels)
I remain curious as to why the MultiRS MPPT tracker considers itself ‘voltage/current limited’ when neither voltage nor current are approaching hard limits, and the system is fully capable of putting more energy into the battery and/or grid.
I have the same issues in two systems with three phase Multi RS systems.
More than enough PV power available. But the MPPT trackers are throttling down and the battery is being fed from grid!
VRM Portal - Victron Energy and VRM Portal - Victron Energy
But when prices are negative, the PV is working at full power. Why not throttle down during these hours and only charge from grid to use the PV power from the neighbours who do not own batteries, and to stabilise the grid, and make more financial gain?
Any progress on limiting this unneeded throttling of the MultiRS connected solar panels while still paying to charge the battery from the grid? I am still noticing this behaviour even with the MultiRS firmware 1.25 and v3.70~7 Venus OS. It doesn’t happen all the time, but it does come up regularly still.
