I have a Victron Orion-Tr Smart 12/24-15A (S/N: HQ2501*****) installed in my campervan. The system worked perfectly for months until recently.
My setup:
2× LiFePO4 12V/200Ah batteries in series (24V house bank)
Orion input connected to 12V starter battery (conventional alternator, not smart)
Orion output connected to the 24V house bank
What happened:
The Orion stopped charging. I checked the wiring and found the positive output cable had come loose from the house battery. I reconnected it with the engine off. Since then, the input voltage oscillates constantly between 11V and 14V while driving, causing the Orion to switch on and off repeatedly and never charge properly.
Important facts:
Before the loose terminal, everything worked perfectly
House batteries are at 95% SOC
The starter battery terminals are tight and in good condition
No sparks when reconnecting
When I disconnect the Orion input cables completely, the oscillation disappears — voltage stays stable at the starter battery
Current settings (engine shutdown detection):
Start voltage: 13.80V
Delayed start voltage: 13.70V
Shutdown voltage: 13.50V
Any idea what could have caused this after simply reconnecting the output terminal?
Thank you
