I purchased a Victron Energy Orion-Tr Smart 12/12-Volt 18 amp dc-dc charger used from a friend. I installed it following the directions. It’s a 12V system. Both grounds are connected together and common to the battery and alternator ground. I measure 12.8 V on both the input and output terminals. The neither the power on or Bluetooth indicators light up. The remote jumper is in place. Is there any type of reset procedure I can use ? Or is it dead ?
Many thanks !
Hi Bob and welcome.
Have you gone through this below?
7. Troubleshooting
If so, check the serial number to see if it’s still under warranty.
Support - Victron Energy
Good luck.
Dave.
Dave, thanks for the welcome.
Yes I did find that page and went through it. I’m guessing it’s bad. My next step is to remove it from the RV for a closer inspection. Maybe try a bench test, I have two 12 V bench supplies. I don’t know how long the warranty is, I’m not the original purchaser so may not apply anyways. I was just hoping there was a reset of some kind.
Thanks for your help, Bob
Hi Bob,
Good news! Most/all of Victron’s products come with a five-year warranty, which can be upgraded to ten years.
Have a look at the details via the link below—you have nothing to lose!
Dave, thanks so much for your advice and time.
I have been out camping with intermittent internet. I’m back home now. I decided to order a new one and get my system running. I’ll inspect the old one and if it can be replaced under warranty I’ll pass the new one on to a friend.
Thanks again, very helpful, Bob
