Translation; “High system load, close sidepanel to unload the CPU”
Has this to do with the CERBO-GX CPU temperature problem.?
Inside control panel temperature is 28 degrees Celcius.
Anyone has experienced this before?
If you search for “close side panel load” you will hit on a few topics but no clear reason or solution. I believe it is from the cpu needing to process too much stuff especially if the side panel is open. Probably depends on how much kit is attached, if you are running Node-RED or any 3rd party add ons.
I wish you could disable this notification thing on the bottom, it’s so annoying
Hey Niels, af few months ago i added a 15kWh Battery and the Smart Shunt
After updated the Cerbo GX, Multiplus2, smart shunt and EVCS to the latest versions , i had no warning like that anymore.
Maybe you can check for updates too!?
It’s low battery for a Bluetooth temperature sensor, but I just want to disable the persistent notification window that keeps coming back. I know I can fix it by replacing the batteries in the Bluetooth sensor but they still work fine so why would I?
