Time to go missing after V3.80 firmware upgrade
The time to go display is missing from the Touch screen after upgrading to firmware V3.80.
Does anyone have a fix?
Is this happening when the batteries are discharging, it does not show during charging. Where is the battery info coming from, all useful info for someone to debug this.
Mine is still showing, data comes from Lynx NG BMS.
Yes not displaying on discharging. The info coming from Victron smart shunt. I noticed only after the latest firmware V3.80 installation.
What GX do you have?
I have a Cerbo GX and a Cerbo GX Mk2
I have solved the issue that I was having with the time to go not being displayed.
I like to compare the JK BMS and the Victron shunt on two level rings.
If I have two levels displaying, Time to Go does NOT display.
With 1 level on either the JK BMS or the Victron shut, Time to go displays.
So my problem is solved.
I have attached two pictures to show.
It would be great if the firmware could be updated to select either ring to displat time to go in the centre.
Is there a Victron site to requested changes to firmware?
I think as you select more rings the room to display the battery details reduces so you only see the SOC, perhaps the formatting has changed a bit for V3.80 so the info shown in the middle drops off with fewer rings displayed. On my Brief display with 4 tank levels as the rings I have only ever seen the SOC in the middle. The time to go should always be seen in the battery on the Overview page.
