Ok thank you , sorry I missed the previous topics . I tried to search before posting. What I did find is that the lynx shunt was not showing it as it had never done a 100% sync . So I will need to adjust the battery settings so that it sees a a full charge to sync the percentage . Then the time to go will display, but only from Lynx shunt .
All devices that have a battery monitor “module” in their firmware can supply that battery time information.
bmv has it, multi rs has it, multiplus has it (if you enable it), possibly all shunts have it…
For victron it’s just a matter of wanting to collect that info from the current set battery monitor and send that info to vrm.
Unfortunately, they sends it only for bmv, from what you are saying…
Who has programming skills, can take a look at the vrmlogger module and add that info, iirc, to the TTG tag, in order to have it on vrm…
If you have a Lynx Shunt and a managed battery then on your GX you can go into Settings > Devices > Lynx Shunt and see that info. If you want it on the display then you have to set the Lynx as the battery monitor rather than the BMS in Settings > System setup > Batteries > Battery Monitor, but leave the BMS as the battery manager in DVCC.
