Hi all,
I’m using a temperature setpoint virtual switch to set the amount of amps my Orion XS are using to charge the battery bank.
While this is working well, the set value always appear with a *C as seen in the picture above (100*C).
In my case, I’d like to be able to change that, or at least remove it…
I use this switch because I can set a 10 value step, so it can go from 0 to 10, 20…100.
Is there a way to change that display in the CerboGX display ? Anything I’m doing wrong ?
thx for the help !
