Hi all, I’m playing with the new Virtual Switch in 3.70 large for temperature in Node Red. When I create a switch, no matter what I set the “step” size to it always is taking huge steps. Changing the step size in NodeRed does change what steps it takes, but they’re always an order of magnitude higher (even accounting for C to F conversion). Video below.
Changing the slider to Fahrenheit in Cerbo settings seems to fix it. I think this is a bug in the temperature conversion (or punishment for American’s who are not using metric system
Mine has the same issue on both F and C. Interestingly on the HTML5 interface it works just fine.
confirmed, this will be fixed.
