Temperature management of Orion 18 A, 220 W charger
I recently installed the Orion charger into a white fiberglass locker in my RV, volume about 0.5 cu M. It is in direct sunlight. It also has a solar charge controller with a 200 W panel. I live in Canada, we have had some 30° + days. I’m a bit concerned about the temperature management for the charger. Does it shutdown if it overheats ? I’m going to buy a wireless temperature monitor to keep in the locker. I have a small 12v computer fan and digital thermostat I could add to direct airflow around the charger if it’s required. The locker is not ventilated but I could add that if needed.
Thanks Bob
As the unit warms up it derates the maximum charging current in an attempt to stabilise temperature. If that fails and it continues to heat up it will shut down.
Thanks so much, just the information I needed.
Bob
