Hi all,
I have a SMA PV inverter (modbus) with battery on AC Out.
In Venus OS the readings of the inverter is added to the AC Loads no matter if it “feeds in” or charges it’s battery.
Why doesn’t Venus OS take into consideration that the inverter is not a “load” if it feeds in and only handle it as load if battery is charged?
So the readings can be added or subtracted per use case.
Yes, I can set it to AC In so the AC Loads are correct but that’s not the system structure.
Thanks
Sven
