I have had an EVCS for 2 weeks. Everything works as expected, but sometimes the display flickers. The hardware extension (small mini circuit board) was included in the package. I plugged it in when I installed the wallbox. If the display flickers, only a reset will help.
Is this a known problem? Has anyone had this before?
Thanks Nicolas for checking this out. I don’t know if it is related but sometimes my EVCS display got corrupted when contactor close/open. The only way to recover is to cycle the power.
Yes, there is a ferrite coil installed, positioned almost exactly as shown in the picture you attached. Additionally, I’ve added another ferrite coil to the data wiring harness, but unfortunately, the display corruption persists—perhaps slightly less frequently, but it still occurs. It seems to be related to induced or transient currents interfering with the communication between the board and the display, but I’m not sure what else I can do to further reduce or eliminate these issues.
If you have any additional suggestions or troubleshooting steps, I would greatly appreciate your advice.
