Then a setting in the shunt is probably responsible. It could be “voltage when charged” … The charging voltage was probably a bit higher than the voltage from the MPPTs … If that voltage is then reached for the set time … the SOC is set to 100%.
You could post your settings … the tail current might also be set too high …
The MultiPlus isn’t actually meant to charge the batteries. And the charge level was constantly well below 100%.
Could the SmartShunt be causing this simply because it hasn’t been able to synchronise for two months? My small solar system can’t always supply enough power.
The jump to 100% is the SmartShunt’s automatic synchronisation, not a fault. The 20 A mains charge maintained the absorption voltage and tail current for the configured detection time, after which the shunt sets the SoC to 100%. The 40% reading beforehand was probably due to drift while it had been counting for two months without a full charge; after a proper full charge, it is accurate again. The console being in French is a separate issue: check the installation’s users in VRM and set a Remote Console password.
Again, this isn’t about the SmartShunt, but about the battery’s minimum SOC setting in the console, which was probably set to 100% by an external intervention, thereby making the ESS practically non-functional.
In the previous messages, only the SOC was mentioned, so you would assume that this refers to the battery’s SOC/state of charge, not the minimum SOC setting in the ESS.
The ESS minimum SOC can be changed by the system itself when the mode is set to “Optimised with BatteryLife”. In all other modes, it does not change by itself.
In VRM, you can check under Event Logs who was in the system and when, but unfortunately not what exactly was done in the Remote Console settings.
What’s your point? I think you suspect a hack and are looking for confirmation. Nobody here can really give you that, can they?
But malicious people can get onto your Cerbo via Bluetooth, your Wi-Fi or VRM. So it’s important that they’re all properly secured with a password that hasn’t been reused, 2FA wherever possible, Bluetooth not using the PIN 00000, and Wi-Fi with a password that isn’t too obvious.
You have to know that the smartshunt doesn’t “know” the actual state of charge in a new installation for example. For that reason I always select the “erase” option in case battery power is disconnected (for who knows how long?), because only after automatic synchronisation to 100% based on measured values over time during charging, the smartshunt will give a good estimate of the SOC%. The manual setting does in fact mean nothing, unless you have a calibration point and measured the current and time continuously
