Hi! The cables from my solar panels show 40V, but once in the 100/30 smartsolar, the app says 0V…and the screws of the charger shows 0V too… i cheked everything 10 times. The positive cable in the positive entry, etc… it was working fine with the bluesolar i just disconnected to use a smartsolar. Is it faulty?
(i’m using: a 480W panel, lifepo4 12V 100ah battery, bestek 300w pure sin wave inverter… 6 and 8 awg cable)
It’s not that…
Or could it be that the entry in the Victron is reversed? where it says +, it’s in fact the negative? Can i test if it’s the case, or can it be dangerous (for me or the charger)?
I just reconnect my bluesolar, and the bulk light is active again (working… not like with the smartsolar, that this led stays blinking)
