SmartBatterySense Monitor no longer providing output
I’ve been using this component for about 2 years with no previous issues.
I noticed an update was available (was on v1.14, update was v1.15). Started the update from my Google Pixel 9 Pro, it paused at 4% for a long time and said the update failed.
Afterwards, the custom name I gave the component (“Battery Monitor”) was replaced with the default name, and the bluetooth pin was also reset to the default.
A few attempts later, after forgetting/reconnecting via bluetooth, eventually the update went through. But while I can connect to the component via bluetooth, it doesnt display any information in VictronConnect. It also wont allow the custom name or PIN to be changed, and it asks to enable instant readout when I select the component in the app. Even though I select “enable now”, it doesnt save the choice and asks again whenever I select the component.
What could the issue be?
