Smart solar 150 | 35 Trends never updates. Settings "battery" blank unless app is forced closed
So basically I’m running a smart solar 150|35 to charge a 280ah Lifepo4 battery. If I leave the Victron connect app even for a few seconds and go back, it has to reconnect. That in itself is annoying, why does it instantly disconnect as soon as you switch out of the app? After leaving and coming back (unless I left the app for a while), it will never update the “trends” information. It will show what’s current with the message saying “stored data is being fetched in the background…” it never loads the info. At the same time, if I try to goto setting, The VE Smart networking is completely missing (screen shot) If click on the “battery” page, it’s completely blank.(Screen shot) The “street light” and “TX port function” pages are also all blank. To resolve any of these issues I have to force close the app, and reopen, or go use another app for a while and come back. Staying in the app never resolves the issue. I’m new to Victron, I’ve only heard positive things about it, this is pretty frustrating though. I’ll also add that this thing’s Bluetooth range is the worst out of any electronic device I’ve ever used in my life. Figured I’d ask before I delete and clear its data to reinstall. Which I’d rather not do until required.
I’m on a Samsung S24 Ultra running Android 14 UI 6.1. Victron Connect version 6.15 (newest as of April 2nd)
I have the same issue, more or less, with my SmartSolar 100/15 unit. When I open the app, the data in Status and History loads just fine but when I go to Trends it fails to fetch the background data most of the time now. The first 6 months of owning the controller this was not an issue. The background stored data would be fetched every time when opening the trends section. Now it loads that stored data about 1 out of 20 times I open the app. I have power cycled the SmartSolar multiple times and restarted my iPhone and reconnected the bluetooth connection multiple times without any success. Is their a fix for this?
