Small bugs 3.50-37
I have the feeling Victron is getting ready to release v2 of the GUI, a good thing. I have two small things that I want to bring to your attention:
  1. After changing a setting (Setup) of a device the device gets listed twice in de Device list.
  1. On the Overview page the names of Devices is use are still based on their function not based on their given Name. As mentioned before, devices in use can have complete other functions than listed in the Victron setup list.
The given name that represents the function:
Good luck with the upcoming release,
Robert
On the overview pages, the levels are over the complete service, they are not individual tanks. To explain, many boats have 2 fuel tanks, perhaps called “Diesel Port” and “Diesel Starboard”. On the overview page, the Fuel line will add up both the fuel tanks, hence it can not use individual tank names. If you only have single tanks then you may not realise this.
Thanks for your reply!
You are right, I didn’t know this. It makes sense to give an overview, or complete service as you say, of the same functions when it are multiple fresh water tanks, diesel tanks etc. But I am talking about a single device/function and used for a completely different thing like showing current water pressure and fertilizer tank level. Even when I have two fertilizer tanks I would not like to see the accumulated amount. When there is only one device of a specific functionality it would be nice to show the given name. In my case fertilizer level and water pressure. As a Avocado farmer I am using victron power in a remote location for watering trees.
Robert
Hey @robert.casadoouro ,
Yes, that feeling is correct!
  1. We’ll look into that asap;
  2. There are possible improvements for that, its listed to look into later; first for now we’re going to fix bugs and release it asap.
Thank you for the report!
Matthijs
Hi again, the tank duplication issue is solved per Venus OS v3.50~42, available now.
Hi Matthijs,
I can confirm the bug is gone!
Robert
