Simple heater element switching for multi rs solar
here’s a way to control the cerbo gx relays in base of solar power.
start is a Multi Rs input,then a filter to stop low value changes ,then a switch to choose the numbers in Watt you want to have switched on/off.Then a change for msg payload 1 or O for switching the relay and finally the seperate relay controls.I use a heating element with seperate resistance ,which are now automatically control by my new toy…It would be even better to have 3 relays in the cerbo,to fully use this way to adress a three part heating element…Frank
The debug nodes help you to understand if and when things go right/wrong​:+1::stuck_out_tongue_winking_eye:
