Is there a way to have a relay of the Gerbo GX switch if the power becomes too high? I would like to have part of my installation switch off if the power measured by an ET112 becomes too high.
Thank you
Thank you
Probably with node red. Got no way to make a flow for you though i do not use the ETs
Ok thank you i look in to that.
Try changing msg.1 and msg.5 to number 1 and number 5 using the dropdowns that now show msg.
let input = msg.payload;
if (input > 5) {
msg.payload = 1;
} else {
msg.payload = 0;
return msg;
just add function and copy this code
I would add a hysteresis or timer to that logic, unless you want to really exercise the relay..
Thank you all with the imput you gave it’s works. And a hysteresis is added.
