Should this washer be here - MultiPlus Inverter?
I just opened the lid on my new MultiPlus 2 inverter (48V/5000VA/70A) before installing it and spotted this washer laying on the DC input PCB. I’m guessing it shouldn’t be there?
Oof, that slipped through Victron’s quality control. That’s not good. Something like that could end badly. I’m planning to buy a Victron system in the future too, but seeing this makes me hesitate. This should never have happened.
I think its a washer that was in the housing somewhere and got stuck there with shipping, you should mail this to victron directly, so they can inform the factory QC
Good catch! Would have made some serious damage
Thanks both. On closer inspection, it’s that same type of washer as goes on the ring connectors on the top of the heat sink for the blue and black cables that go off to the toroidal transformer. I guess someone was fitting them, a washer fell off and was replaced without finding the missing one. Not great.
That prompted me to check mine. I already knew that I would probably find the PVC cap used on the WiFi antenna receptacle. The slots at the top could be a bit smaller to reduce the risk when handling lose hardware.
Good Night,
Well, the PCB says Quattro (photo above), so its not a Multi, correct?
But that doesn’t mean that washer is correct!
Ok, send this photo and the full number (with photo) to your supplier, they can then forward that to QC of Victron (like a RMA), this, as from that production this person might have made more of such mistakes, and they can back-track that person and also the other apparatus produced that time…and torture that person till death…well, you know what I mean to say…
Besides, it was tested, and it it passed, but, are you sure it will operate as should be, no, we wouldn’t take the risk and advise to make a full RMA to substitute this apparatus before even using it yourself, see our point?
After a good test, they then should “short circuit” the capacitors (battery connection) to empty them, but if at that point that washer fell down, then there is most probably already damage done to these components on the PCB…
Then, eyes closed, you have 5 years guarantee, and see it works, later very hard to prove it was that washer…
Regards, Jeroen.
Yes, follow Jeroen’s advice and don’t put the device (Quattro II) into operation or switch on the power supply!!
Initiate an RMA; the part needs to be returned and dismantled so that we can draw further conclusions if necessary (optimising quality assurance, local manufacturing, and training local staff on the critical importance of missing components).
Where was it manufactured? I’ve also installed a few Quattro IIs that I’d like to check to see whether they might be from the same batch or production period!
Thanks for the replies people. I noticed the Quattro marking on the PCB myself but it is a MultiPlus 2 but I’m not surprised if some internal parts are common between the two units - why make two different 48V DC input boards.
Anyhow, I have sent the photo to my supplier in the UK and they have been in-touch with Victron but I’ve not heard back from them yet.
I’ve done a thorough visual inspection of the unit and the rest looks fine, I’m holding off powering it up as long as possible for Victron to reply but I also have a deadline by which I would like this system working.
A.
Here’s the information sticker for the unit…
Thanks! I’ll check my systems too.
I found in my MultiPlus 2 inverter (48V/8000VA/100/110A) a very strong tiny button magnet in the bottom of the unit when I accessed the unit to make the connections. Feedback I got from my supplier was that they were used during assembly to hold components together. Seem like there are 2 factories leaving things behind my unit was made in India the one in the topic made in China,
Just because this happened once with one device, there’s no need to take every MultiPlus apart…
Sure, it shouldn’t happen, but it can sometimes.
Why?
I’d say it’s enough to report it to the authorised dealer so they’re aware of it and can pass it on to Victron if necessary.
Then remove the washer, connect the DC and switch it on.
Either it goes bang or the unit runs perfectly normally.
I’m pretty sure the unit will run without any problems.
Yes, I gave it a thorough checkover and everything else seemed fine. Gave it 48V from the battery bank last night and it powered-up OK - no bangs and none of the magic smoke escaped, so I think it should be fine. I’ve not given it AC input yet but the issue wasn’t in that part of the unit.
