Good day,
I’m a complete beginner with electrical so please bear with me ![]()
So I was using my Wesco WS3434 radial saw today to make a battery box for my new LifePO4 battery and Victron MPPT (mounted to outside) and when I went back in the boat I found my shore power had gone out. I used my voltmeter to track shore power current to a junction box where power was going in but not coming out. When I opened the box I found several wires and wire attachments all melted into balls of plastic goo and a strong melted plastic smell (Image01-02).
So I looked up my saw and found it is 1400 watts (Image03).
And I looked up the Mass GI Transformer Isolater (Image05-06) to see the installation instructions and specs. Mine is the version 3.5, in column 1.
There are two separate sets of wires in the box. The grey wires- shore power in to Mass GI Transformer in connected together, and separately 4 black wires connected together.
What struck me right away was that the worst melted wires (grey ones) were from the shore power in to the Mass GI in, which were completely charred and melted, leaving one wire unattached as the white plastic connector had completely gone to black goo.
Also I noticed the yellow wire with the green stripe which is ground in (image06), was not connected at all, both ends snipped and just left there disconnected. Also, there is no GFCI or fuse that the (image06) instructions called for.
Next I noticed the black wires which come out from the Mass GI to the junction box and split to a couple electric outlet wires and a power inlet to the battery charger were also melted.
However on this end the ground wires are connected, but again, no GFCI as called for in instructions, and no fuse.
I don’t know how long the boat has been like this, but I’ve used shore power almost daily for a couple years since I bought it, and run more powerful devices like a 2400 watt water kettle with no problems until now.
Any Idea what went wrong???
Scary because I read the number one cause of death on boats is actually fires. And I’m staying on the boat now, so double scary.
I’ve always wondered about grounding on a boat, as someone I was told was a very reputable boat mechanic said never connect a ground to say a metal plate on the hull, which makes contact with the outside (water) as some kind of electrical corrosion can cause huge damage to your prop, prop shaft, and engine. So I’ve always wondered what people do with ground wires on boats. Now I NEED to know.
Any shared wisdom greatly appreciated!
