I have an LFP battery consisting of 18 cells in series and I would like to know if the SmartSolar MPPT 150/35 could provide a charging voltage of 64V.
You can use the VictronConnect application, the one that configures the MPPT, in demo mode and check if it can.
I tried the demo version, there it allows me to set up to 69.56V. But I doubt that’s the case.
According with the in cause MPPT’s documentation, as long as the default equalization voltage for certain type of lead acid batteries is set to over 68V, then I suppose that your case of 64V is an obtainable, realistic value.
Thank you!
