Ruuvitag shows as disconnected with Battery Life firmware on tag
Just set up some Ruuvitags, the process was fairly easy.
There is a firmware for Ruuvitags that only updates every 10 minutes for battery life extension reasons.
I’ve noticed that between updates the Cerbo GX shows these devices as disconnected, I assume because it hasn’t check in often enough.
Is there a way to extend the detection time for a Ruvvitag that isn’t updating within 10 minutes?
Is this from the Ruuvi app?
Hi i have a lot of Ruuvi tags and have not seen this issue, can you post some pictures of this please?
Do they appear in the Cerbo GX Device List like this below?
DL
And VRM
If viewed in VRM mine all update every minute or two, when you say "extend " do you mean longer that 10 minutes or a shorter timeframe say every 5 minutes?
Can i ask please what you are monitoring with you tags?
