After I connected my first ruuvi sensor, it doesnt update information in vrm. Only the values reported when installed is showing. I’m using globalink 520.
what is wrong?
what is wrong?
Is it still showing in Device List or in IO menu. If you are not at the installation then check using Remote Console. If it is there then I am not sure why it is not logged on VRM.
Thanks for your answer. It was caused by poor bluetooth signal. Solved the problem by placing the ruuvi closer to the globallink. But a little bit disapointed by the range of the bluetooth reception by the globallink.
