This topic is interesting because I have four Ruuvis and the D-Link UB400 Bluetooth USB dongle, and everything works fine, or almost. Let me explain. For your information, I’m using v3.53.
When I’m using a remote console via the network, clicking on “Levels” clearly shows my four Ruuvis. However, when I’m using my GX Touch, I only see three sensors. I’ve tried everything and nothing works, so if you have any tips, thank you in advance.
Moved out of the beta testing section as your issue is clearly not a beta problem.
Simple thing, have you tried scrolling / swiping the screen sideways on the GX touch because 3 Ruuvis may well be too wide to display on the GX Touch with both temperature and humidity shown. On remote console the screen may be wider and able to accommodate all the Ruuvis. If you have 20 temperature sensors then the temperature screen is very very wide so you get used to scrolling sideways.
Hello @pwfarnell , thank you for your feedback, yes you are right I am not in the right post, but in order to answer you yes I tried scrolling right and left, in this case I go either to the Overview screen or the notifications screen ![]()
Up !
