ROLE for energy meter not present
I have installed 2 pcs. of VM-3P75CT one measuring mains, and one for the solar system.
They both show on the device list (canbus2)
I do not seem to be able to find role, anywhere in my setup. I am logged in as user/installer.
Hi @RobotKarsten, the VM-3P75CT can be configured using VictronConnect. This can be either locally over LAN or remotely via a GX device on the VictronConnect VRM tab.
Hi
I still do not find role, can you be more specific.
/Karsten
Do you mean here ?
Hi @RobotKarsten VictronConnect is a program / app, not the GX device itself. This is different than for the Carlo Gavazzi meters you might be familiar with. The instructions for changing settings can be found in the manual here.
Ah, thank you. I see it cannot be done from the VRM portal or the local hmi. ONLY from the victron connect app.
Thank you, it works fine now.
/Karsten
Victron Connect works over VRM from a PC. I can see my system and make adjustments.
