Remove "AC Loads"
Hello!
I have been trying to find a way to hide the “AC Loads” block in my system.
as you can see, i have 1 PV inverter in ACI, 1 PV Inverter in ACO, and all of my loads are in ACO1 this setup requires a meter in ACI so thats what i have, but when I select it in my ekrano, it automotically pops up a AC loads block and a critical loads block.
is it possible to hide the ac loads block?
thanks!
I agree and have previously questioned a similar concern.
On my Installation, Dashboard, there are two informational boxes that I have no need of and are not at all relevant to my off-grid installation.
They are:
”To A/C Input” and From “A/C Input”.
I hope that your question receives a more positive response than mine. I look forward to removing what for me is the unnecessary clutter.
Good luck!
There is a setting in the GX device, there you can set that loads are only at AC OUT and that will hide the AC IN loads.
it doesn’t.
Once i tell the system that the grid is measured by a external meter, it automatically activates the ac loads box and the critical loads box
Same here, would like to disable AC Loads too. Keep in mind we’re only talking about VRM here, not remote console.
Exactly, remote console is ok, just looking for a cleaner vrm experience
Just for testing, could you try to “move” the PV inverter on AC IN to AC OUT in the configuration?
it has no effect. the system is designed that if a grid meter is present, the system must have critical loads, i am trying to understand what is the reason behind this.
The majority of systems with a meter have loads on the input side.
In the old UI, under ESS, was a “has AC loads” option under the meter selection. This used to remove that box iirc.
I agree. There are not so many systems that need it.
Is victron considering fixing this in a future update?
Few months later an I am seeing the same issue.
Any update or did I miss the fix for this ?
no fix yet!
Yeah same problem, waiting from VRM team fixing of this problem. Did they have any support/issue service?
not yet!
is there an update on this FR?
