Update 3.52 removed AC Load and Essential Load
Since upgrading to the GX to Version 3.52 the VRM stopped reportng on my AC Load and the GX display stopped showing Critical/Essential loads.
I have changed the GX to make use of the new UI:
VRM:
Device List:
I found on the community area that previously if someone wanted to have AC Load and Essential load combined together you needed to disable “Inverter AC output in use”. Under the new UI version this setting is not available. Changing back to the old UI shows this setting is enabled which I was under the impression should keep AC load and Essential load split.
I have done more testing and still can’t figure out how to resolve this issue. I would like to see the different between my AC Load and Essential load.
Any suggestions are welcome
I got the inverse problem :smile: do not want to see critical loads, just one block with the loads like you but also do not know how to change it
First, try rebooting the Cerbo, install the latest official firmware, ensure the position of the loads are set as required in system setup and you also have an energy meter.
My solutions was related to custom software that needs to be installed on the GX. The services provider that provides me with a Water heater timer running on the GX resolved the issue I had.
