I am currently commissioning my installation consisting of a Multiplus 48/800/9 and a Venus GX connected via VE.Bus; I am trying to control the charging and discharging of a battery in ESS mode 3 using a Raspberry PI with Python in Modbus; but I cannot find the list of accessible registers (I launch my requests with the service unit-id 242 which corresponds to the multiplus);
I managed to identify two simple registers: battery voltage and battery charge current, because I ran a scan of the readable registers in two states:
-1/ Battery only connected (and I then see 42.2V and 0A charging in the console)
-2/ Battery + AC-IN connected (and I then see approximately 42.2V and 6A charging in the console):
I identify hence:
Register 840: 422 // DC voltage of 42.2V
Register 841: 61 // Charging current of 6.1A
To continue and control the charge, I’m stuck at this point.
I’m looking for the following registers: Grid Power Setpoint, Charge Authorization, Feed-in Authorization.
I’m also interested if you can advice me other way from Modbus-TCP, to control the charge or discharge of the battery using python SW.
Thank you,
Sorrry but in the fil “CGXModbus-TCP-register-list.xlsx” i don’t find the same registers as i have scanned with python and my gx venus device.
Here the registers i would like to write:
(Registers 36-37-38):
|ESS power setpoint phase 1|37|int16|1|-32768 to 32767|/Hub4/L1/AcPowerSetpoint|yes|W|
|ESS disable charge flag phase|38|uint16|1|0 to 65536|/Hub4/DisableCharge|yes|0=Charge allowed;1=Charge disabled|
|ESS disable feedback flag phase|39|uint16|1|0 to 65536|/Hub4/DisableFeedIn|yes|0=Feed in allowed;1=Feed in disabled|
