Because of physical constraints, I want to install a Class T Power In, a Lynx Shunt, and two M10 Distributors in a Right-to-Left orientation, with the cables still entering from below (as opposed to mounting everything upside down, requiring the cabling to enter from above).
As I understand it, the Power In and the Distributors don’t care which side is “Source” and which is “Load”, but clearly the Shunt does. Random chatter online suggests that I can simply re-wire the insides of the Lynx Shunt to support a R-to-L config. Is this true, and if so, is it supported? The User Manual (page 10) doesn’t address the topic.
Obviously I could mount just the Shunt upside down, but that would mess with the unit-to-unit interconnect and require a bunch of short bus bars and generally just look and feel awful.
