I am connecting two M10 Power In’s with a shunt between them. One unit will have the 4 battery connections on it and the other side is all the inputs like
External Chargers, Inverter/charger etc. I would like to have those big terminals go out of the unit on the right side instead of the left side (I don’t want to turn it upside down if possible) I am looking at one of the units and am starting to wonder if the bus bars inside can be reversed so the part that extends out of the unit can be on the right side? i see that there is a small plastic plate that can be removed and switched to the other side, But looking closely it the bars the Phillips screws aren’t placed symmetrically. The engineers couldn’t have been that shortsighted, could they? -Bill
PS. I had to use the Distributor Tag as power in isn’t a choice and it wouldn’t let me edit it.
