I’m building my first home battery system and ran into a problem with the direction of the Victron Smartshunt. I want to place it between the lynx power-in and lynx distributor on the negative bus bar. The initial idea was to order the devices like: Lynx Power-in, Smartshunt (neg. bus bar, on the positive there is a switch) and Lynx Distributor. Problem is that this would require the smartshunt to be mounted upside-down, which in turn would make the VE.direct and AUX connectors inaccessible. (see ch “ 3. Installation ” of the manual) It would not be more than a little hassle to reverse the order (i.e.: distributor, smartshunt, power-in), but it just not seems logical that I would need to design the layout around this one component. So am I missing something? Or this is it?
Thanks!
