Lynx Class T power In & Lynx Shunt
Can the new Lynx class T (M10) be interconnected with de Lynx Shunt (M8) by making the holes on the left side of the Lynx Shunt bigger to fit the M10 on the Lynx Class T?
Would this be safe and work properly?
Is there a Lynx Class T in M8 version planned for the future?
Thanks in advance
Or alternatively from my point of view - would we be able to purchase replacement bus-bars in M10 for older Distributors and Shunts? (aka upgrade kits?)
In honesty I don’t think it is an issue connecting them electrically. It is the flat surfaces that transfers the majority of the current. As long as washers are large enough - M8 bolts through the M10 hole should be ok if both units are bolted safely onto a surface. But it would be better with larger hole.
Upgrade kit as you mention would be a great idea. :raised_hands:t2:
Did you end up doing this? I am looking at possibly doing this to change from a Power In to a Power In T Class. The other alternative I am looking at is fitting a Littlefuse L15S fuse in the shunt.
