kp4djt
(WC)
1
This is the full message:
A network security profile has not been selected
To access the GX via your web browser, first select a security profile.
There are 2 methods available:
- Method 1: On the GX touch screen, navigate to Settings, General menu.
- Method 2: Using the VictronConnect App, connect with Bluetooth and there select the profile.
I have never seen this in the past when creating RPi images and accessing them for the first time.
I tried VictronConnect as it sees the RPi BT but it tries and fails to connect. The on second attempt says there is already a device connected.
What is work around to this?
kp4djt
(WC)
2
This is the beta file for the RPi 2 family. Up until now they have always just allowed me to connect to the device and configure it.
kp4djt
(WC)
4
I got a work around I loaded the main line code then did an upgrade to the beta, that gave me access.
mpvader
(Matthijs Vader)
5
Hi all, just to confirm: we’ll look into this on our side.
Thank you for the report, Matthijs
(V #1367)
kp4djt
(WC)
6
Thank you, as I indicated I was able to work around it by loading stable code into a clean chip, then I went
in and did and upgrade to beta.
We are using the Victron devices on our solar powered microwave sites, and so we will be testing all manner
of things.
TheITBoat
(Brian Clarke)
7
I can confirm this issue, I need a method of recovery remotely as I don’t currently have local access.
mpvader
(Matthijs Vader)
8
Hi all, thank you for the report. Fixed per Venus OS v3.50~32
TheITBoat
(Brian Clarke)
9
Is it possible to recover this with local keyboard & screen access?
