Cannot access BT or Wifi: Venus OS on RPi 3B+
Hi there,
This is somewhat a frustrating experience, I downloaded and flashed the latest Venus OS large image and can boot it on a Raspberry Pi 3B+.
I see it in Victron connect, but if I want to connect it fails, telling me to reboot the phone, etc. No success.
I then tried to setup WIFI on the Rpi, first, there is no raspi-config (why?!).
Then the OS is read-only. After re-mounting it rw and changing the WPA-Supplicant it still doesn’t connect after reboot.
How do you actually set this up?
Can anyone please help.
Thank you in advance!
I played around with a pi3b+ 3 days ago, and upon first connection (Bluetooth) had some issues as well. After 3 connection atttempts, the app always said, that this device is already connected to another device.
I re-flashed the micro sd 2 or 3 times to reset and start over, and without any noticable change in “the process” it finally worked.
Pin to use was 000000, despite the phone is suggesting 0000 or 1234.
This is probably the worst experience ever… why they take such a limited image is beyond my understanding.
Nothing installed, not working as in the description… that really sucks.
The PI Image is provided free of charge, allowing you to fully utilize features, including cloud services etc.
It is released for DIY Purpose, so you shouldn’t expect to get a plug and play experience.
If you want that - then buy a cerbo that ships preinstalled and ready to run.
Which image did you use? The pi3b+ requires the image for the pi2, not for the pi4.
I’ve followed the instructions over here:
(used the win32diskimager ) and including errors / 2x reflashing it was up and running within 15 minutes.
I didn’t expect a plug and play experience, I just expect it to work as advertised in the docs - which it doesn’t.
It wouldn’t be a problem to fix it, hadn’t they chosen a completely stripped down image.
i have spent around 9 hours over a few days trying to make it work.
i am using Pi4-B which some sites suggest is the issue ,however there is a new Venus OS update from 24-9-24 which is alleged to work on the Pi4 B , its just not working for me.
I get the splash screen and line root@raspberrypi4:¬ # , If i try to convert to headless with;
mv /etc/venus/headless /etc/venus/headless.off
it says can’t rename Read Only file system.
i installed SetupHelper on to a USB stick , inserted that and tried the commands in Kwindrem’s Github page as a blind install but nothing would run despite rebooting a few times.
If i enter the following to make the root file into read / write gives me “making the rootfs writable”
/opt/victronenergy/swupdate-scripts/remount-rw.sh
i again enter mv /etc/venus/headless /etc/venus/headless.off
Hit reboot > enter
Hey presto >>> ITS WORKING IN GUI !!!
This also worked for me. Thank you.
I installed 3.33 on a 4B and this worked. I updated to 3.55 and GUI did not function. I ran the commands you recommended once more, and GUI function was restored.
I had a problem connection to Wifi on my Rpi 3b+. After a few reflashes of different OS versions, and switching Pi hardware, the solution was that I had to disable WPS support on my router.
