Quattros in parallel - How to restart the system if one units break?
I have a boat with 4 Quattros wired in parallel and a Cerbo GX.
I know that if one of the Quattros breaks and goes into failure the system stops working and I see an alarm.
If this happens while I am sailing, is there a way to restart the system by excluding the broken unit?
I know I can use the VE.Bus Configurator and modify the system. I’m asking if there is a more user friendly way, like using some settings on the Cerbo GX or an assistant.
Thank you
No unfortunately, the broken unit will need to be physically disconnected from the VE.Bus network, and the system needs to be reconfigured for the remaining configuration.
If you haven’t used VictronConnect before to commission multiple units I would suggest getting familiar with that before your trip. It makes the process very fast and simple, but I wouldn’t want to be doing it for the first time at sea.
