VEbus Quattro and Cerbo GX connection problem
System configuration:
2 quattro 24/5000 in parallel (firmware 510)
1 Cerbo GX (firmware 3.54 or 3.42)
1 Multi Control
VE-bus cabling: Multi-Control - Cerbo GX - Quattro master - Quattro slave - (MK3 USB to PC).
Problem: when the Quatro’s for one reason or other switch off (error or accidental switch off button) then I can not restart the Quattro when the Cerbo GX is connected.
Exemple: Manual switch off master with the on/off switch. System stops. Switch on master again, nothing happens. Then disconnect the BE-bus cable (or power off Cerbo GX) and the system starts up again. Can then reconnect the VE-bus.
So when there is/was a problem, I have to disconnect the Cerbo GX to be able to restart the Master and Slave Quatro’s. Very inconveniant.
Remark: When starting VE.Bus Quick Configure on PC, it can not find the Quattro’s at first attempt. But I notice that the Device is then removed on the Cerbo GX screen. Second attempt is then succesful to connect to the Master and Slave. Restarting the Quattro after reconfiguration (of assistants) is then no problem.
How can this be solved to make a restart after error more reliable?
