Pylontech Pelio power cables compatibility
Hello all, please I need help as I cannot find anywhere Pylontech Pelio power cables.
Only common 2m pylontech battery cables compatible with US5000, US3000… bateries. Question is, can I use this cable also for Pelio battery? does anyone know?
Or better, where can I order original Pelio power cables in Europe?
I know there is groud kit and wall mount kit, but there is only one pair of cables included, but I need more cables and not whole mount kit again. One cable is rated to 100A so with more Pelio batteries I would like more cables as I need to “unlock” better discharge current and that cannot be done with only one pair of cables.
Thank you.
Can’t see any difference on the pelio-ground kits, on the power cable. Looks like a regular 4 AWG with Amphenol connectors.
So, cables for the USxxxx Series should be fine.
Maybe send Pylontech a mail, the Amphenol connecters are available in different sizes as well, and for stackable batteries, it should (theoretically) be able to handle sizes for multiple modules, which a regular 4 AWG may not.
(and using thicker cable with connectors rated 120A wouldn’t make all too much sence)
This is Pelio “hole” for cable, as you can see, there are visible diferences,
and this is original pelio power cable I found on austalia market:
But common Pylontech cables are not visually like this.
And when you have 4 of Pelio batteries is paralel but only one pair of cables to inverter so this batteries can last long but only 80-100A discharge. But this battery is rated for more, you can get 80A only from one piece but not if you connect them together with only one piece of cables to inverter…How else should I get maybe 300A+ in total of discharge current (in victron 3x 5000 setup)?
Thank you.
I have the same problem and am looking for cables for the Pylontech Pelio batteries.
Does anyone have a solution? The US cables suggested above do not fit :frowning:
