If you have Cerbo MK1, maybe your (separate) CAN-BMS module is having a slight problem.
At some point Victron changed some parameters for that (external) CAN module.
In other order of ideas, do you use a good (or genuine) CAN cable? Is the CAN terminator properly inserted on the Cerbo side?
