Does anyone know how to plug it in correctly? The connector has only grooves instead of the nose and I can’t find any info or photo about it in the retrofit documents. Thanks in advance
Turn it around, line up plug(has protrusions on one side only)with socket groove ( has gap on one side only)and push home.
Oh dear, Google translation.
If I interpret this correctly, marked side plug with marked side socket plug together. Just as it should be. or… why no plug with swapping protection nose was used, no idea. Damage would simply be stupid. Thanks and greetings
