Phoenix inverter stuck in overload and green light flashing... any help greatly appreciated
Hi I’m new here… Iv been using victron stuff for about 15 years in many off grid projects. Like small (300 people) 100 percent solar powered music stages. So if you have any questions about this I can help.
Ive got an odd thing happening with my 12/3000 phoenix inverter I think its year 2000 model.(old model)
I got the inverter green light flashing and a constant red overload light on.
There is no load on the inverter.
I fully disconnected it and disconnected my ac cable thinking there might be a short in my cable.
my cable was good.
Then I measured across the earth neutral and positive ac terminals in the inverter and they are all connected? I mean all connected together???
I have no clue what’s going on here.
I can send a current across from positive to negative to neutral with my multi meter.
It seams like a short but nothing is burnt wiring looks as new. Its clean and moisture free.
My question is :Has the inverter gone in to a locked in a safe mode due to another problem or has the unite just failed in some bizarre manner.
I have an either net cable to try and find a error code but seems I have to order a V.E. converter to connect to the phoenix.
Help please/// Thankyou!!
Unfortunately, this LED state usually indicates an internal fault.
This is not really clear?
Hi mike cheers for getting back to me.
when I say : [quote=“argon, post:1, topic:24542”]
[/quote]
i mean if you put a probe on the AC positive and probe on ac negative or on earth they are connected together. Example: you would have the same result if you had an ac cable with all 3 wires touching each other this would result in a short across all the AC terminals.
This is what confused me as this could only happen if something had burnt out or if there was another internal problem and that is what the victron phoenix does when its in a safe mode to lock the inverter state to over load. I dont know.
Worst case I can open it up further.
I’m not familiar with this inverter, but if it is a design with high frequency transformer and FET switching on the output (light weight unit), then your measurement indicates a burnt output stage.
BTW, AC connections are normally referred to as “live” “neutral” etc, not as positive and negative - the latter are reserved for DC.
